Murray one wheel kart
gravey32
i recently got a murray kart, has one wheel drive, has 212 predator, but it feels like it dont wanna go sometimes, i just put new clutch, it does seem to squeal/chatter some still, any ideas...
Smerft85
Southern Colorado
First guess is gear ratio. Supply us with the tooth count on the clutch sprocket and the axle sprocket, as well as the tire size of the drive wheel. Should be able to get it straightened out.
gravey32
10 tooth clutch, lawn mower tires, and im assuming original sprocket, not sure size on it
Smerft85
Southern Colorado
10t clutch is a start, if you have 18" tires and a 10t axle sprocket it will burn a clutch before it moves. Need the details, exact counts and sizes. The more you help us, the more we can help you.
Smerft85
Southern Colorado
From the picture I'll run on educated guesses, tires look to be 15x6.00-6, with a 10t clutch you need a 60t axle sprocket to make it perform. I have a manco two seater, same size tires, 10t clutch and 60t axle sprocket with a governed predator 212cc, one wheel peel just like yours and it will roast the drive wheel with two adults in it totalling over 300 pounds. I'm guessing your issue is in the axle sprocket, probably a 54t if I'm guessing which would give it more top end speed and less torque than a 60t. Let me know if I'm correct.
gravey32
wheel spins, like it will go sometimes, but not predator 212 go lol, then there is times i can have it floored and it jus sits there, my throttle dont sound all the way either, ill get tooth count tomorrow, its dark out already
Smerft85
Southern Colorado
When you push the pedal does it for sure open the carb all the way? Might have slack in the throttle cable causing you to only get a portion of available throttle.
gravey32
that may be the culprit, cuz i lifted cart and gave it full throttle and it sounded alot meaner than by gas pedal
Smerft85
Southern Colorado
Adjusting the cable is pretty straightforward, make sure the black sleeve stays stationary, and the cable doesn't have any slack when not depressed, just tight enough the pedal and carb work with each other with pressure on the pedal. There might be an adjustment point by the pedal, there is guaranteed a way to tighten it up a bit on the predator. You'll have to check and assess on your own though.
gravey32
yeah mine may be rigged some, i watched a few youtube vids and they all bring cable from side to tighten to throttle assembly, mine im pretty sure went in the back, and has a big spring attached to muffler, ill have to look at it tomorrow
gravey32
Here's a few pics
gravey32
so i put sum 10/w30 oil on clutch bearing n it seemed to take noise away, but it still seems like its slow to take off.. probably just my gearing, would it hellp if i get 12t clutch instead of my 10t
