I will have to try that. I only have two chains on my setup. We put a brand new centrifugal clutch on it but what initially happened is the band of the brake went over and actually hopped onto part of the so causing a lot of extra friction. Then the clutch got pretty hot. I adjusted the brake by bending the mounting rod a little bit to make it not so close to the chain. We took it out for another test and it did better but still struggled to climb a small hill in the grass. Maybe the clutch was just too hot yet and not working properly. Also, maybe the axle bearings are not the best…
