murray hard drive axle
trooper3455
Tennessee
Hey guys, I'm new to the go kart world but I bought a hard drive go kart that needs tires. I cannot get the rear wheels off the axle they're froze up. I could use some help getting the entire axle out of the frame then I can press the wheels off, I removed the bearing keepers but I don't know how to get the axle to fall out. Please help
Welcome to the forums.
A bit more info & some pics would help your cause :)
What type of bearings; cassette, flange or pillow block? Look for grub screws where the bearing meets the axle.
Have you disconnected the brakes & removed the chain?
trooper3455
Tennessee
Yes I removed the chain and brakes I'm not sure what you call the bearings theres a plate that's formed to bolt up against the beaing on the wheel side and it has 2 carriage head bolts that fit in square holes.
exopo
i have same go kart
i just bought this go kart and have same problem, i tried everything.
trooper if you could email me pics of your jackshaft it would be greatly appreciated :)
That helps, a little. undo the nuts, support the read of the frame & pull out the bolts. Your axle should then drop out.
trooper3455
Tennessee
My real problem is trying to take the wheels off they're seized to the axle so I thought if I took the axle and all off I could take it to the press and get it off. I figured out that the axle will not come off with the wheels still on. any ideas?
TripleT
Iowa
I had that problem.They where just rusted on. Get a hammer and something to put on the axle to protect the end(if your going to use the axle) so your not just hitting the bare axle. If possible get someone else to pull on the tire. Also the piece to protect the axle would help if it was round.
