Hello all,
First go cart build. I got a Murray Nitrox? frame for cheap and built it up with a predator 212 and jackshaft. Couldn’t find a way to mount the engine with torque converter on the old engine mount so I mounted it in the center with a jackshaft. Had to get a new axle because one of the rims was fused to the axle. I would have went with a new live axle but liked the support of the old axle throughout the frame. So far so good but had some questions maybe someone can help with.
I got a new seat with four mounting threads on the bottom that are about 14” apart and the mounting brackets on the go cart are 23” apart. I was thinking of using square tubing on the sides so it can be slid back and forward but am unsure what to use across that will support the weight and not bend (not the best welder but I can make metal stick together). Angle bar? Square tubing? How thick? Hopefully my pictures attached. One has the old seat in it. I priced out new cushions and got an entire seat for cheaper that has more of a bucket seat style with better seat belt options for the kiddos.
What lube is used with the pillow block bearings I used on the jackshaft? I see people using regular axle grease. Will that suffice?
Lastly the new flanged bearings I used for the axle are not sealed on the inside. The old ones were completely sealed. The axle they were placed in is sealed should this be a concern?
