Moving Kill Switch
smithky
Hi all i want to move the kill switch thats on the engine up to the steering wheel for easier access how ever when i removed the switch it only had 1 wire running from the switch how do i wire it up thanks
[/URL][/IMG]
The kill circuit grounds out the coil primary to shut the engine off. See the metal tab on the back of that switch? That's the ground contact. In the OFF position, the switch completes the circuit to ground.
The best way for you to add a remote kill at the driver's seat is to put that factory switch back on the engine where it was, and get yourself an SPST toggle switch. Tap into the wire that goes to the factory switch, and run that wire up to wherever you mount the new switch. Connect that wire to one terminal of the new switch. Connect the other terminal of the new switch with a short lead to a metal grounding location such as the steering column support brace.
Keep in mind the folowing:
1) The circuit must be closed (grounded) to kill the engine. If new switch does not shut engine off, there may not be a good metal-to-metal contact between the engine block and your chassis. Clean some paint off, or run a wire from any bolt on the engine to the chassis.
2) If you wire the switch in a parallel circuit as I suggested above, BOTH switches must be in the ON position for the engine to run. If either switch is off, it will not run.
smithky
ok got it moved works well now another problem im having is the engine runs fine but after riding for 5 min or so it just cuts out randomly can start it again ride for 30 sec cuts out checked the oil sensor and disabled that still does it any ideas?
J_Walker
Florida
Sorry, I feel the need to ask all the simple questions around here because sometimes it seems needed...
Is it chugging before it gives out? do you feel the engine do something, or does it just shut off?
If it's just shutting off. the mod you made to your switch is touching something causing it to engage the ground. Electrical tape is your best friend!
J_Walker
Florida
was it doing this before you modded your kill switch? if not.. then its something you did differently to cause this. Post pictures of your mod, and I, or someone else will try to walk you through it. I gotta go to bed, its 2:31 AM again... :/
smithky
it was doing it before the mod and all i did was connect a wire to the wire that was attached to the old switch and placed the 2nd wire to a bolt on the engine
J_Walker
Florida
Is the boot over the spark plug coming lose? Press it down real tight - it should click. It sounds like an electrical problem for sure...
A spark tester would be worth millions here. You would be able to see whether it's losing spark, or if it's maintaining spark and losing fuel.
smithky
but it dies as if i flicked the kill switch once it dies it dies wont respond to throttle or anything
Are you able to hookup a different switch as to eliminate that as a possible problem. there might be some loose connections causing a short somewhere.
Multiple millions.
To eliminate the switch(es) as the source of your woes, just disconnect them all, and test.
Now- This sounds very much like a low oil sensor issue. Look at the first picture you posted at the top of this page. On the far right hand side of the photo is a yellow wire coming out of a hex fitting. That is your low oil sensor. I want you to do two things-
1)Check your oil level, and top up as needed. Fill it until the oil level touches the threads in the oil fill port where the fill cap screws in.
2)Unplug that sensor wire. Now, take it for a good test run and see if it quits again. Report results.
smithky
ok so its full with oil as done oil change on it i already have disconnected the oil sensor when it first shut off thinking it was the problem after reading a topic on it and it still died tested the switch and completly disconnected it still does it
smithky
the other wires coming out of the engine look fairly old could they be shorting ?
smithky
fiddled with all the wire but still after the engine been running and warms up it just dies im out of ideas
smithky
ok so if i lift the cart up one way it turns its self off disconnect the oil sensor and it doesn't die when lifiting it up only when u start taking corners.
