Mounting throttle cable
Imbo
Young Mechanical Genius
Garden City, NY
Very noobish question but i just got my 6.5 hp honda clone and i was guessin mounting a throttle cable was easy but this bad boy has no hole to put a bolt through and i dnt wanna brake it. any tips would help. pics would be much appreciated
Imbo
Garden City, NY
yea i was thinking of that but still it leaves the coduit just moving so it dosent work and theres no where to mount the conduit
Imbo
Garden City, NY
thats pretty helpful but i dont wanna be drilling into my engine or takin it apart...i might just put the retainer screwed into the air filter cover
daveb
I just put mine together. I drilled a hole in the throttle lever and used a bicycle gear shift cable. I attached it using brake hose clamps. I will try to pst a pic.
daveb
Here is my set up. I put an extra spring for the throttle return . It is circled in black and the other side is attached to the cover over the muffler. I drilled a 1/8" hole in the muffler cover.
I circled in orange where the throttle cable attaches to the throttle. it is a small hole I drilled there also. I used a clamp there to hold the cable. I forget what they call it (it's a barrel that a screw goes into and it clamps down on the cabe). The outr jacket is held down by a small break clamp . It is circled in orange also. There was a hole there allready if I remember correct.
jfoust
Atlanta, GA
The AGK kit that devino246 linked to works great. I just got done doing mine with the AGK kit and had it installed and running in no time flat. Well worth the purchase.
Imbo
Garden City, NY
i had my brake cable and a couple pieces from my old vex robotics kit and bent a piece to an "L" shape and put the cable through and you take of the air filter cover, theres a spot with a hole thats coming off from under the gas tank and another hole on the opposite side of the throttle lever wich i bolted it to. no drilling required. parts used:
!-piece predrilled metal bent to an L
2 screws
2-keps nuts
4-washers
throttle cable
EXTREMELY simple on the harbor frieght engines
