mounting plate
kendelrk
redneck engineer
westland michigan
So i have someone ready to weld up my motor mount, but its so thin and gone im ready to get a thicker, and nicer one. i need one EXACTLY like the one on my baja, but i cant find specs and i dont feel confident with what i got for measurements. i need it thick, mounting holes for my predator, and i need my engine to allign correctly. anyone have any suggestions?
Measure 10 times, cut once. Make a template out of a sheet of paper by laying it onto your existing mount and rubbing your fingers on it. Slightly dirty fingers will help a lot. Pressing the paper over the edges and holes will help, too.
If you're expecting to find a thicker, aftermarket plate that's going to be a bang-on fit for your application, you may be expecting too much. Find a steel supplier and go get a piece of 3/16" plate and fab one. You could even go a bit thinner with a gusset or two. There's only so thick you can go before it's pointless. More important than super-thick, is how it is attached and supported.
r97
Measure twice cut once
Massachusetts, USA
A 1/8" inch plate with some 1/8" gussets worked excellently for me. IMO if you use a 1/4" plate with a small engine you are just adding unnecessary weight, fab time, and cost. Personally I would just add gussets to the current plate unless it is .065" or something ridiculous like that.
kendelrk
redneck engineer
westland michigan
i feel like after welding 3 times, its time to just go with a better plate. i have only found 3 online and the one thats best for me is 9 x 5 but my original plate is 12 x 6
kendelrk
redneck engineer
westland michigan
They don't accept the clone mounting config. I'll buy the 9 x 5 and set it to the front and use some of the old plate welded up to make the 6", I also will be reinforcing with some steel bars and such to make a super strong mount
r_chez_08
Should be in the shop...
Cornwall, UK
Just buy a plate of steel thick enough (using specs given above) and cut it up. It is not too hard.
:iagree:
All you need is a drill and a hacksaw, a file and some time.
A jigsaw or even better a mill helps but the slots can beads with basic tools.
