Motorized drift trike project
ChrisT
Lincoln, UK
I seem to have accumulated the makings of a project so I thought I throw up a few pics and ideas, see how it goes.
For those unfamiliar with drift trikes (there are some others on this forum) have a look here - http://www.youtube.com/watch?v=nfYAsnRQ-co
I don't have a huge expanse of tarmac to use but there is some waste land near the workshop so I'm hoping I might be able to make a kind of dirt track drift trike - it might not work in which case I just put some PVC pipe over the tyres and use it on the bit of private road out front of it:thumbsup:
First off I got some kart rear wheels, wets so they're slightly more suited to off road use than slicks.
http://img.photobucket.com/albums/v326/mantachris/SP_A0961_zps1d809727.jpg
Made up some hubs from some tube, turned the end down to fit inside the wheels and welded a disc and some bolts to it....
http://img.photobucket.com/albums/v326/mantachris/SP_A0965_zps53d0e87c.jpg
These will be welded to the axle (more tube from the workshop), which will have a sleeved join in the middle so it can be removed.
Found some bearings, might change them to the 2 hole type as the smaller housing will make mounting easier. The axle will probably end up narrower than this.
http://img.photobucket.com/albums/v326/mantachris/SP_A0966_zps6685d3c0.jpg
http://img.photobucket.com/albums/v326/mantachris/SP_A0968_zps2f7c45c2.jpg
Got this cheap on the weekend which will donate it's front end and some of the frame.....
http://img.photobucket.com/albums/v326/mantachris/SP_A0974_zpsf2a000c1.jpg
and made these foot pegs for it out of some stainless tubing I'd had in the shed for years - knew it would come in useful eventually....
http://img.photobucket.com/albums/v326/mantachris/SP_A0971_zps1568c1f6.jpg
They fit to the front forks using the wheel nuts.
This evening I picked this up.....
http://img.photobucket.com/albums/v326/mantachris/SP_A0976_zps8bce8273.jpg
http://img.photobucket.com/albums/v326/mantachris/SP_A0975_zps19eac585.jpg
It's a Honda G65, 6.8hp - a bit old but it starts first pull and seems to run ok. Float bowl needs a new gasket, obviously the 'filter' will be replaced (have a cheap K&N style one) and the exhaust is rusting away but I wanted to make a new one anyway.
Will probably replace the tank with a custom made one at some point.
So that's it so far, a throttle twist grip is on it's way, just need to get a clutch, axle sprocket and chain.
All opinions welcome, first time doing something like this so please tell me if you think I'm on the wrong track.........
ChrisT
Lincoln, UK
I like that honda...
It's obviously had a bit of a hard life on closer inspection.
Fuel tank has been stood empty so either needs cleaing or replacing, petcock needs a new seal and filter, fuel bowl seal is leaking (knew that) and judging by the amoung of debris in the petcock/bowl/tank I'm going to have to strip the carb and clean it out......
ben.s.
like it. im in the progress of gathering parts to make 1 atm. just need go kart rear axle or something like.
got a midi moto crosser to use the engine and whatever else, and cut a bmx so its ready to be assembled. :p
keep us updated! :)
ChrisT
Lincoln, UK
^^^Sounds like an interesting project, looking forward to seeing a build thread......
Engine seems to run ok.....
http://www.youtube.com/watch?v=y4zp18_3-fY
Choke needs to be mid-way otherwise it stalls, guessing not enough fuel which ties in with having crud in the system blocking a jet.
Mocked up a few parts too, just to get an idea of how it might look.......
ChrisT
Lincoln, UK
Bit more of the frame built, once I know where the engine is going to sit I can finish off the rear end properly and figure out what to do with the top of the bmx frame.....
Looking good. Have you thought of how you are going to connect the axle sprocket and brakes to the axle? Is it keyed?
The axle is pretty close to the ground as it sits now, and I was just thinking that you are not going to be able to put a sprocket of any decent size on there as it sits now. You will have to use a jackshaft to get the gearing you need.
You could mount the axle above the frame and therefor create more sprocket room
ChrisT
Lincoln, UK
TBH I'm making a lot of it up as I go along as parts turn up or I get inspiration - I went through three different ways of mounting the axle the other day before settling on one.
I'm planning on making a carrier for the sprocket (and for the rear brakes when I get round to them - going to see how just the front one works to start with) and bolting it o the axle.
I don't see what you're getting at with the ground clearance for the sprocket - mounting the axle above the frame is not going to change the distance it is from the ground, that's governed by the wheel size surely??
Got a selection of sprockets from ebay today, they are a smaller diamter than the wheels/tyres so should work.
Did a bit more work to the frame today, engine is only mounted temporarily, it will be moveable to allow chain tensioning.
jace
Spring,TX
you are correct, sprocket size is governed by wheel size, the frame has nothing to do with it.
ChrisT
Lincoln, UK
That's what I thought:thumbsup:
Checked my selection of sprockets and they're all smaller than the tyres so that's good.
Made up a sprocket carrier and finished off the frame today....
I have a slight problem with the output shaft of the motor being 1" - it seems most clutches are 19mm.
The shaft is plenty long so I was thinking of cutting it down and making up something wide enough one end to go over it and the other end turned down to 19mm.
But I found an exploded view drawing of the motor on the interwebs and it looks like the cranshaft splits (to allow removal of the conrod) so I'm now thinking that will fit in the lathe ok and I can just turn the shaft down......
ChrisT
Lincoln, UK
It would appear it's impossible to split the crank without some kind of press/puller - was hoping I'd be able to do it without removing the piston from the bore but it's not happening :(
The bearings are pressed on and block any access to the crank pin.
Back to plan A then......
At least it's given me the chance to look over the engine a little better, oil has definately seen better days, plug is past it's best but internally it's fine as far as I can see. Did find the wire to the condensor almost worn through where it's been rubbing on the inside of the flywheel so that's been replaced.
Cleaned up the carb before refitting it - blew through everywhere and no obvious blockages, had noticed before that there were three holes just above where the throttle flap is (something to do with letting air past it when it's closed) fairly sure they shouldn't be visable from the outside though so need to make a bung to cover them.
Also made up a throttle linkage - the original one incorporated a governor which I've done away with. The twist grip pulls the cable about 50mm but the throttle flap lever on the carb only moves about 10mm so had to make something with a 5:1 ratio.
Bodged together a return spring too, not overly impresed with the bracket but it works which is the important thing at the moment - once I know it all works I can refine/improve parts....
And made a start on the fuel tank, reckon I can make a rubber gasket to replace the worn original on the fuel tap. Welded a plate to some tube to mount it to, just need to seal both ends and find a filler neck/cap.....
ChrisT
Lincoln, UK
ahh, did look at the weights on the cam and wonder if I should remove them, I'll put it on the list of things to do......
Made up a rubber seal for the fuel tap to replace the damaged one and blanked off the bottom of the housing where the filter should have been, will run an in-line one instead.
Got the fuel tank made up, using the cap/neck from the old one and mounted to the engine, not leak tested it yet though.....
ChrisT
Lincoln, UK
Thanks, and it actually holds fuel on first test:thumbsup:
Got the clutch and chain the other day and made a start on an adaptor to take the output shaft down to 19mm....
http://img.photobucket.com/albums/v326/mantachris/SP_A1027_zps6251369b.jpg
Slotted the holes in the frame for the engine so it can be moved back and forth approx. 50mm to aid chain tensioning/removal. Made up a tensioner bracket so the engine can be kept in place while tightening the bolts up, it can be mounted either in the far end of the slots or the holes behind depending on where the engine needs to be...
http://img.photobucket.com/albums/v326/mantachris/SP_A1030_zpsdcbd6940.jpg
Got the output shaft adaptor finished off, will be fixing it with an M8 shoulder bolt rather than the m6 currently in use.
Had trouble getting the clutch far enough on though so have mounted it the other way round, can't see any obvious reasons why this wouldn't work, will probably put a cover over the end to stop and dirt getting in.
http://img.photobucket.com/albums/v326/mantachris/SP_A1037_zps832928de.jpg
For now it's just getting a chain guard, have left the shaft coming through the clutch just in case I think it needs a bearing support that end.
http://img.photobucket.com/albums/v326/mantachris/SP_A1039_zps88a20fe9.jpg
http://img.photobucket.com/albums/v326/mantachris/SP_A1040_zpsb86e714a.jpg
and I'll end with a video of it 'working', carb needs some work, mixture screw doesn't seem to have any effect, although it was doing something the other day...
http://www.youtube.com/watch?v=3cnPMQbmHoE
ChrisT
Lincoln, UK
Been thinking about what to do/how to make a decent seat, I want something with a bit of side support, have been watching ebay for a kart one to turn up at the right price but yesterday my mate had an idea - use a kids car seat, he just happened to have one spare......
http://img.photobucket.com/albums/v326/mantachris/SP_A1042_zpsd6d7c89d.jpg
So, with a bit of cutting about you get this....
http://img.photobucket.com/albums/v326/mantachris/SP_A1045_zps3e2a5a3c.jpg
And with the carb running better today it was time to test the clutch and throttle cable arrangement....
http://www.youtube.com/watch?v=LkZHDbQvQbg
Bogs down a bit when opening the throttle but I'm sure that can be sorted with some more tweaking.
Took it for a test drive across the workshop (only about 6m of clear space) and it actually moved, which is good, and seemed to be picking up ok :wai:
