James.Ait.2013
The Village Idiot
If you aren't getting into the new craze called 'drift triking' you are missing out!
http://i1299.photobucket.com/albums/ag71/NetworkFart/photo-778742_zps094ea166.jpg
The original drift trike looks like this. it all started out with this idea. the huffy slider then quickly went viral and this is what has come of it.
http://youtu.be/R9K-MzMN2w4
my design is to just use a racing tarmac go kart axle. and so the whole thing will slide or 'drift' there is a trick to the whole operation. you deflate the tires, then slip some Pvc pipe or PE pipe over the tires. then you re inflate them so they expand and hold the pipe in place. in theory you dont need more power to drift. you just need less grip.
and this is where i start. i have bought my huffy slider.
http://i1299.photobucket.com/albums/ag71/NetworkFart/P1070091_zps8c608c32.jpg
and this is the victa motor i want to put on it. it started life on a victa 160cc lawnmower. and the found its way onto our home made battery charger that the engine runs a alternater to charge a 12v battery for when we go camping.
http://i1299.photobucket.com/albums/ag71/NetworkFart/P1070095_zps02eb611c.jpg
I have bought a shaft adapter and a Max Torque clutch through my work for my project.
[http://i1299.photobucket.com/albums/ag71/NetworkFart/P1070101_zps735fc397.jpg
i have a Walbro chainsaw carb to put on the victa to fire it up a bit. its got an inlet of just below an inch, the old local fellow that used to race victa go karts told me that you need a chainsaw carb that has an intake of around an inch. anything smaller you will increase torque and the bigger you go the more HP. and with a higher revving engine= more speed. and this is why we build these things isnt it?
http://i1299.photobucket.com/albums/ag71/NetworkFart/P1070096_zps51513ab8.jpg
so my main concern right now is to buy a set of racing hubs and wheels. ill be sure to keep you posted as i go. any help with info on go kart axle with sizes and places to purchase them would be great. thanks.
with Landuse and Mysteryboy. that's a major stress point. You could add 2 tubes on either side to make a stronger triangle shape, but that may hinder your removable idea.
