HellSpawn
you mean a cable barrel?
this is my "complicated" design, its prob not really needed(prob even slows down shifting), but i think its kinda cool. pivot on frame, rod going through pivot, arm welded to rod, shifting rod (supported like redsox said) through a hole in the arm welded to the pivot rod, end of pivot rod (or maybe on top) are two tabs with holes drilled in them, shifting arm (the one your hand goes on) has a hole drilled in it, a bolt goes though one of the tabs on the pivot, then through the shifting arm, then through the other tab to a nut, then you have a spring on this shifting arm so it wan'ts to swing to one side. this shifting arm sticks up through a metal box with slots on it that are in the right place so when you shift to a gear you pull the lever to one side, move it forward, and it swings into one of the notches. i have a simpler idea if you wan't to hear that one? bolt though frame, compression spring over bolt, shifting lever over bolt, nut, that goes in the same type of metal box as the first idea, and works in much the same way, would work good for an e-brake. i can make a sketch up if any one is interested/doesn't understand what in the world i am talking about, lol
Yeah, but I don't believe in buying tiny parts, I create my own o:
