The kart isn't gonna pull uphill with smaller tires. The 15s already lose traction in places. The clutch is 10t and driven is almost as big as the tires already. Probably not an option.
---------- Post added at 11:07 AM ---------- Previous post was at 11:04 AM ----------
I wonder what the deal is with that motor and high elevations? I'm interested in buying it but I'm at right under 3,000 ft.
Well higher elevations means thinner air. Thinner air means less oxygen.
Less oxygen with same carb jets, means the engine will run rich. You'd need smaller jets OR maybe a performance intake and exhaust. This will HELP move the Air / Fuel Ratio in the correct direction and improve performance.
I'm just guessing. Not sure how well it will perform. I'm not a mountain man.
---------- Post added at 11:48 AM ---------- Previous post was at 11:43 AM ----------
At high altitude, the standard carburetor air-fuel mixture will be
too rich. Performance will decrease, and fuel consumption will
increase. A very rich mixture will also foul the spark plug and
cause hard starting. Operation at an altitude that differs from that
at which this engine was certified, for extended periods of time,
may increase emissions.
High altitude performance can be improved by specific
modifications to the carburetor. If you always operate your engine
at altitudes above 1,500 meters (5,000 feet), have your servicing
dealer perform this carburetor modification. This engine, when
operated at high altitude with the carburetor modifications for
high altitude use, will meet each emission standard throughout its
useful life.
When the carburetor has been modified for high altitude operation,
the air-fuel mixture will be too lean for low altitude use. Operation
at altitudes below 1,500 meters (5,000 feet) with a modified
carburetor may cause the engine to overheat and result in serious
engine damage. For use at low altitudes, have your servicing
dealer return the carburetor to original factory specifications.
Even with carburetor modification, engine horsepower will
decrease about 3.5% for each 300-meter (1,000-foot) increase in
altitude. The effect of altitude on horsepower will be greater than
this if no carburetor modification is made.
http://cdn.powerequipment.honda.com/engines/pdf/manuals/37Z5F602.pdf
