Hello all, couple of questions:
Just bought another go cart. Pretty good size yerf dog, only paid $100 for it and i only had to replace the carb. It appears to be the same as the following link:
http://cf.mp-cdn.net/fb/31/3108b6c4e02372f3e5b6b9a86ba1.jpg
This only has a 6 hp engine and i want more power. I plan on using this engine on a fourth go cart that is awaiting an engine. I have found a lifan 15hp at home depot for $250. I believe this is the best deal. There is also a briggs and stratton 11.5 for $277. What size or brand would you go with? I honestly have never had good luck with a briggs. I recently purchased a generic baja from tractor supply that i was very pleased with so i am not too nervous with going with an off brand but i do not know anything about the lifan engine. The baja is on another go cart of mine. With this type of go cart what types of speeds would i expect with the 11.5 or 15 hp?
secondly, the current engine has a 3/4 shaft on it. This type of go cart has the belt and chain setup. i do not know much about these because i am use to the simple clutches.
The new engines that i am looking at all have the 1 inch shaft. Am i just able to buy a new clutch that is a 1 inch for the shaft coming out of the motor? How expensive is this? Can someone send me a hyperlink with the part i need? I assume this go cart has two clutches. One that is connected to the shaft coming out of engine that is belt driven and the other that connects that belt and chain together. Is it possible to eliminate one?
thanks in advance, jody
