I have a yerf dog 3020 and I am running a Honda GC 160 and a torque converter on it? Will I see a huge difference by putting on a Harbor Freight 6.5 engine, Speed, torque?
Top speed is related to gearing and revs, not HP. You could have a 50HP engine that turned 3600 rpm and it would go any faster, just accelerate much quicker.
I'll jump in and play Devil's Advocate. While the above may be true with ALL other things being equal, the theory becomes false when you factor in the following-
The 50hp can be geared higher! It will have much more oomph off the line geared higher, and because it's geared higher, it will ultimately go faster.
You got it. Pedantic? -I would prefer to think of this as ensuring that everyone is as close to being fully informed as possible.
thanks, to go faster would I put a larger sprocket on the axle?
