Motor / Battery Selection
ColonalPanic
Hey guys,
I'm trying to build my first go kart totally from scratch. I need to find a motor and battery that will work for me. Heres my general plans:
- The frame will be made of 1/2in steel pipe, both welded and using fittings.
- It will be 350 lbs with me in it TOPS.
- It will have 3 (12v) batteries in line, or 2 (24v) batteries in parralel. Whichever provides the best power for cheapest.
- It will have a 24v motor.
****TL'DR*****
I need help getting a motor and batteries. I want the cheapest components you know of (used or new) that will provide OK preformance. I'm open to any suggestions as well. Thanks!
EDIT: How would this be for a motor? Boehm .18 hp Motor on Ebay
beachkat
Wouldn't 3 - 12volt batteries in series give you 36 volts?
The motor looks a little puny to me but I don't really know. You're pretty light so maybe......
ColonalPanic
Yeah, I want to overvolt it. I'm 150 lbs, and I want to get it to around 15-20mph.
ML-TOYS
long island, new york
i have one of these in my garage
Model: MY1020 Motor By Unite Motor Co., Ltd.
Type: Brush
Voltage: 36 Volt DC
Rated Speed: 2500-3000 Rpm
Rated Current: 17.8 Amp
Sprocket: #25 Chain Sprocket
Output: 500 Watts
Sprocket: Removable Bolt Sprocket
Case Length: 5-5/16" (135 mm)
Case Diameter: 4-1/4" (108 mm)
Drive Shaft Length: 1" (25 mm)
Drive Shaft Diameter: 5/16" (8 mm)
Mounting Hole Distance: 3-3/4" (95 mm)
ML-TOYS
this is what it does in the kart
Speed
Approximately 18 MPH
Acceleration
0-10 MPH in 2.3 secs @ 120 lb load
Volts
36V
Vehicle Weight
130 lbs
Max Passenger Weight
220 lbs
Max Distance traveled per charge
10 mile
Length of discharge
40 minutes
jman231994
Australia
I personally recommend going with a higher voltage....From experience with an electric bike last year, 36v will almost always beat out 24v due to the current draw advantage. Weight killed our chances of winning an event, we had nearly 40aH of lead batteries on board for 24v and we only just stood up against the 18aH 36v bikes. We had nothing on the hills.
