journeyman846
- Messages
- 24
- Reaction score
- 5
I have been waiting on the BMS for over a month now (stupid AliExpress) so I haven't had a chance to really charge the pack. I've also only done a couple short test drives and have monitored the voltage after every one so I am not too concerned with cell damage. I am going to try and charge the cells using what I have for now and see if the RPM's come up.Did you check your battery voltage? Did you charge those cells individually or in parallel with a bench power supply? Be very careful with using the battery without a BMS. Overcharging and over-discharging can easily damage individual cells, but individually charging the cells for assembly and testing is safe; just don't go too long and risk over-discharge when you aren't monitoring the cell voltage.
