more torque please
azarak
central Texas
pred 212 (non hemi).
need more torque.
have- pod air filter, rejetted carb (38 main,140 emulssion tube), header & rlv muffler, 4* timing key, AR3910X plug, low oil float removed, governor still intact.
series 30 tav with a 12 t on the jackshaft turning 72t on axle with 12.5" tires.
problem is i need more punch out of the motor. several corners on the (dirt) track i drive on are very tight and bog the motor. I am happy with my gearing and don't really want to lower it any further.
all of the products i research seem to be aimed at more hp and higher rpm's. i need power at the low end.
one answer would be remove the gov, drop the gear ratio and just rev the $#!% out of the engine, but i don't currently have funds for flywheels and con rods and the bits to keep my engine from becoming bits due to excessive rpm's.
can you guys help steer me in the direction of a quicker revving, more torque producing engine?
more advance on spark?
high comp head?
longer exhaust (header i have is only 8" long single stage, thread in muffler)?
KartFab
Dallas, TX
Have you tried a #37 or #36 jet? #38 seems a little rich?
If that doesn't work, governor removal and keep the stock valve springs to prevent excessive RPMs
Just so you know, increasing hp without increasing RPM = more torque!
Perhaps a low end cam will make a difference...
One important factor to consider is the size/weight of the kart itself. My GX160 has buckets of torque but, it's on a lightweight kart...
