kbf1961
Im building a go kart for my son , I have a 6hp B & S engine from a rototiller. Can I disconnect all of the governor linkage and connect the throttle cable directly to the carburetor.
Kevin
Kevin
that's not recommended.. no
the governor itself is a plastic part with steel inserts.. when you rev the engine much higher than what the governor is meant for (which is possible if you bypass it)
it CAN shatter and destroy the engine from the inside.
here's an example of a shattered governor
Fortunately the engine wasn't damaged in that case, but it is highly probable that it will be
