getting it going
heres an idea that all racers do. Pull the flywheel key out and advance the flywheel about an eighth of an inch. You can buy off set keys, just make sure the flywheel is tight and you will be alright. other ideas, deck the block, port the intake, surface the head, open up the jet and drill the carb high speed side, ream the carb body, get rid of the stock cam....I can go on and on.....
