Jake.B
So guys i just picked up a late 80's to mid 90's yz60 2stroke dirtbike. Gas leaks out the fuel exit on the carb, pretty quick. It starts up and idles good but once i get into high rpms in 1st and 2nd gear it cuts out a ton. Im guessing a carb clean, sounds to me as if the needle is resting on gunk letting the fuel drain out and when it starts to suck the gas up its all gone because its draining out the carb.
