More carb & fuel stuff.
Logan County Ohio
I intend to put a GX390 carb on a stroked 196 clone with a "252" cam. I have the adapter intended for this purpose. My question is; What kind of idle problems might I expect. Must I change e-tubes, if so to what? My guess is that vacuum will be reduced and the mixture will be lean but I have no experience with these little guys.
One of our guys has a predator using a gravity fuel system, he was going to go to a pump and remote tank but hadn't got that far yet. He showed up at the track with an adapter plate with a blocked pulse fitting in place of the plastic insulator thing, still using gravity. His idle sucked, changed e-tubes, still sucked, changed e-tubes back and took the adapter out and replaced it with the insulator. Purred like a kitten.
My question is; Am I going to have the same issue if I try to put a GX390 carb on my predator? The insulator thing must effect the idle circuit somehow. I'm trying to keep the intake runner long for torque.
