Modified Predator 212cc Idle issue
XxbossdogxX
Hello everyone, I've just finished modifying my predator 212cc and when i start the engine it idles at a ridiculously high rpm. When i pull the throttle cable it revs even higher (so the throttle isn't stuck or anything). I have a mikuni 22mm carburetor and I've adjusted, what i believe to be, the idle screw and had no change in idle rpms.
engine mods:
Black mamba camshaft
billet connecting rod
billet flywheel
22mm mikuni carb
autolight AR-3910x spark plug
26lb valve springs
*pic of the "idle screw" that i'm adjusting (please point out to me if this is not the idle screw)
Any help would be greatly appreciated, I want my go kart running ASAP.
Thanks!
P.S. - I searched google already and found no help :p
2SlickNick
American Minibikes @ FB
Mesa, AZ.
I have a vm22 chikuni carb on my mine too. I pretty much have my idle screw turned all the way down and to idles a little high...
But if you think about it it's a bigger carb and allowing more fuel in... so I think that is to be expected. I love the way my carburetor performs. Also if you're unsure which crew take the air filter off and look at the slide and see if it moves up or down when you adjust it. You can do this with the engine off.
XxbossdogxX
No, you don't understand. My engine is idling VERY high (like 5000 rpm). Also are saying that turning the screw clockwise lowers idle speed?
2SlickNick
Mesa, AZ.
I never said anything about turning it clockwise, it should be counterclockwise to lower the idle speed. Maybe post a video maybe that would help.
Kentucky Boy
Bowling Green, KY
Is your throttle cable to tight, under tension? If your cable is too tight the carb slide will not go down enough to lower your idle even if you adjust the screw. Check your gaskets for an air leak.
XxbossdogxX
No my cable is not too tight. However I may have an air leak, could you explain to me how that would affect the idle speed. Also how do I know that I have an air leak. Thanks :)
---------- Post added at 02:04 PM ---------- Previous post was at 02:00 PM ----------
Ill get a video out asap
KartFab
Dallas, TX
Might want to read up on the carb users manual. There's no way you are idling at 5000 rpm without some serious opening. We have these same carbs on my dads Honda 4 stroke engines that are 200 cc and you can adjust the idle just fine. The carb has a lot of things that can be adjusted, so I'd like to reiterate looking at the users manual to know where to start.
If you have an air leak ( wether through your Venturi because the slide isn't shutting, or through the intake manifold gasket being damaged, or installed incorrectly, it just lets air into the engine. Provided you have enough fuel supply, if more air gets into the engine, it revs higher.
Staff Murderator
The video doesn't help much but to illustrate that, yes, you have no real idle speed to speak of.
You have something seriously wrong there, chum.
P.S. Neat hand grip throttle.
XxbossdogxX
ok guys, after some reading and tinkering i'm very sure that I have an intake leak. All of the symptoms are textbook matches. I believe i have a vacuum leak through the gasket (which I may have installed incorrectly). I ordered a new gasket and will keep you guys updated.
