Minor difference between old a new carb... Important?
emudryj
South Florida
The carb from the clone GX200 on the carter brothers I'm trying to bring back to life needed a good old cleaning (it would only start and run choked) but after briefly looking around I found a standard carb for that engine costs $13-15 so I got me one, rather than going crazy cleaning the old one.
After I order it I noticed a minor difference between my carb and the picture from the one I bought and it was on the choke wing lever...
The new one arrived today and, though is worse than what I thought, I believe it will not make much difference so I wanted to confirm with you guys...
As you can see on the pictures.. the current choke wing lever is metal and spring loaded to stay on the open position and only close when pulling from the choke handle.
The new one is plastic, not spring loaded and would stay open when pushing the choke handle rather than when pulling it...
Is this that big of a deal?
I could see how to remove the system on the old one because the wing is attache with a couple of screws... but the new one seems to have been "pressed" to the shaft and cant see any civilized way to remove it...to replace with the old one.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Looks like your new carb is missing the lever to open and close the choke. I don't know if my pic is too small but do you have the manual choke lever on the new carb that rides this (blue) rod
emudryj
South Florida
Yes I do... is the manual choke lever I've seen on other small engines... I do have it... why? I thought that it would be an extra part that I would not need on my application, but I have it right here.
The new carb is simply a superceded (updated) version of the old carb; as long as you have the choke arm to fit the new carb, I don't see a problem...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
:iagree: Fabro man is right.
I only asked about the arm cause I was thinking maybe that was your confusion on the butterfly seeming to work backwards. Also I noticed because I just cleaned the exact same carb Sunday.
Why do you think you don't need it thou. How do you put the choke "on" to start a cold engine without it? Did I miss something?
emudryj
South Florida
I may have expressed myself wrong... I'm no saying I do not need the choke to start a cold engine, what I was tring to say is that I thought the extra plastic "manual from the engine" lever was needed.
The original carb has spring loaded arm that keeps the choke butterfly open by default. the butterfly has a metal lever (you can see it on the attached pictures, that has a "choke" cable (or wire I do not know what would be the correct terminology) going all the way to the seat. So in theory, since the engine has an electric starter, you can pull the choke from the seat, turn the key and get it running from the seat.
If I use the additional plastic lever on the new carb choke butterfly I could only choke the engine manually standing next to it only.
I think I'm confusing you guys more than clarifying the issue...
I will try to connect the choke cable to the new carb and just remind myself that while seating on the cart, pulling on the choke cable will be the normal running position and pushing on it would be the cold start position. and be done with it...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
No thats clear. You have wire run to the seat and can choke it from there. That is cool.
That does change things a little...
You are correct with the operation of the cable but, there are one or two ways around that:
- you can reroute the cable so it connects from the rear of the carb or
- add the plastic arm & connect the cable to it by drilling a small hole in the arm...
emudryj
South Florida
Yes... as you can see on the pictures attached the choke wire is loose just dangling around the seat.. I've been looking for some type of "U" bracket welded to the frame where the choke wire should be attached to, but I have not been able to find it...
