Minor crack causing oil leak
C4Kid
Hi Guys,
This is the first issue I've had so far in my build:worried2: I've just noticd a tiny crack around the bolt just under the filler plug on the side over of the engine. It's oozing a few drops of oil when left sitting.
I'm just wondering is there anything that can be done without sourcing another side cover ?
Thanks in advance.;)
C4Kid
Thanks for all the info :thumbsup:,
I've just picked up some JB Weld and will probably have a go at it later tonight. I might take a few pics for anybody with a similar problem in the future.
Why did it crack in the first place?
It's Jiangdong JF168 so I'd say the quality of the metal isn't the best. The crack should be an easy repair due to it's location, around the bolt below the filler plug. I'd say the bolt was over -tightened in the past.
Might I suggest drilling a hole at the end of the crack first to keep it from cracking even further. then fill with JB weld.
Yep will do, that's the only way to insure it's fixed properly.
Good luck with Your projects! :)
A culmination of the above, plus some...
Drain oil. Drill a small (1/32") hole at the end of the crack. Use a Dremel or mini die grinder to vee out the crack along its length. Use #120 or slightly coarser sandpaper to slightly roughen the area around the repair- this will give the epoxy (JB) a good tooth. Clean the wee out of the repair area with Acetone, MEK, Toluene, Methyl Hydrate, denatured alcohol, or any other good solvent, let dry, and repair with JB Weld or other good epoxy. It'll last forever.
