Minibike lost 10mph
Dk@t
Get the rotary or comet belt. Also please post a picture from above of your driver and the driven ( also from the rear ) so we can see the alignment of the two clutches. On the 30 series, alignment has to be almost perfect. Misaligned clutches causes premature belt wear on an awful lot of karts and bikes. Kind of just like you are experiencing.
I don’t believe my cvt driven and driver have been misaligned but I haven’t checked them in a while
I’ve hit 50 and had a fine time with this last belt from the same pack but maybe I’m having bad luck with this one….
What are you using to measure your speed? Just curious.
Its been proven over and over that the cheap belts just dont last. Some make it longer than others but all fail at some point.
The good belts will last. BUT, the cvt needs to be smooth and lube properly and aligned.
Ive never seen my belts get sticky goo. Thats the "rubber" breaking down.
When the belt slips or gets narrowed from missing material it will not fully engage the cvt. This leads to loss of power across the power band.
Compare the belts together. Im curious to see what they look like.
Can you get some more pics? Maybe turn on a light too, its hard to see.
This is a great one-post reply on the CVT, belts and issues thereof. Nicely done. That could be a “canned response”, something you could copy/paste ad infinitum. 🏆
Dk@t
I have been using an app called “speedometer” and here are some of my test runs when attempting to diagnose the bike myself
Dk@t
I am happy to say that I found the problem, I bought a new chain, it came with a new 60 tooth sprocket and I thought “why not”. As I was getting ready to put on my new chain I find my rear sprocket is bentIMG_1726.jpeg
And when I go to test after putting the new rear 60 tooth and chain I hit an astounding 48 first try! something I haven’t even been able to do for some time then I hit 50!!IMG_1730.jpeg
Dk@t
Not a fair comparison for belt slippage when you just changed the gear ratio.
And I'm pretty sure a bent sprocket won't affect speed.
I still plan to put the comet belt on but it was decently bent and the chain was old, I will do more tests to see if it’s consistent but this generally fixed it.
Your alignment looks pretty close. In your 3rd picture it looks like the driven is a little more out board than the driver. OMB Warehouse ( and probably others ) sell shim kits for this exact purpose. The shims are .020" thick. A common hardware store washer is about .050" thick. Yours looks less than .050 out. Getting them near perfect has its benefits. I've had belts last for 25 + hours of hard run time. Probably 300 miles or more. The shims are cheap, and the results can be well worth the effort.
Dk@t
I was able to mess with it and get it this close, but sadly my belt was delayed to arrive after I left so I’m going to have to use this belt and redirect the belt or refund and repurchase it to the location I’m staying
JimD
Naperville, IL
Since you have shown me the cover of the t/c I was going to suggest drilling as many holes as you can into it to let out the heat build up which helps to ruin any belt. The series 30 is wedging the belt up and down on the inside sheave versus rolling with the angle of the pulley on the series 20. There is a lot more heat build up inside the cover and the quicker you can get it out the better the life of the belt on the series 30.
Dk@t
I’m sorry I missed your previous message, but I don’t use a plastic cvt cover are you talking about the cover on the clutch?
Dk@t
Some more pictures of the belt
Is that “pit bike” muffler any good? Got a link for that or is it common as dirt?
...I am happy to say that I found the problem...
You found and fixed “a" problem or merely changed the gear ratio like WTR said, which was limiting your top speed.
If the bent sprocket were a real problem it would be throwing the chain or some such. That being said, a straight chain on straight sprockets does provide an edge on speed but not a whole lot. A bent sprocket and wobbling, vibrating chain represents a bit of power loss no doubt.
