sorry, been busy lately, the output is gear up, as is the input on mine, and its currently topping out at 52 MPH since I re-geared it recently. I have added rear suspension, we are still working it out to see if it works, so its off the record, lol. the 820 trans is all steel cut gears, not pot metal or sintered like the cheaper ones, the big failure point on the cheaper ones is the main axle ring gear, and the 820's ring gear is 3-4 times as big, and better quality. yes the bushings will wear out, but they can be ordered from any tecumseh/peerless dealer. you definitely need to over engineer the mounts for any transaxle your using, as the biggest failure point on racing mowers is twisting off the axle housing ends, because the heavy front of the trans isn't properly supported when you are bouncing along offroad.
I used my transaxle as a transmission only, this will GREATLY increase its life as the axles are under a static load, which helps the gears and housing not get flexed which helps start the damage process. if you were running a cheap transaxle with a 8-12 hp engine and centrifugal clutch on a light weight street cart, it would hold up well, I used a cheap tranny, but the weight of me (350lbs) and the buggy (another 500+) was too much for it.
