mini bike motor
rocko
just last weekend i bought my friends mini bike frame for 40.00 u no that old school type i have both wheels including the one with the sprocket attached so now all i need is a motor.well just this morning walking down my ally i found a toro snow blower and it runs perfect and even has electric start the only problem is it is a two cycle motor not a four.is there any way i could use it maybe with a jack shaft to lower rpms so i could ase a clutch and if you know could you tell me the gearing:confused:
RobertD
Administrator
Texas
go kart clutches lock up at 2200 RPM. So, you'll need to get it down to around 4000 RPM max.
RobertD
Administrator
Texas
it's going to depend on what gears you can find available, but in a "pure" sense...
if the engine turns 10,000 rpm, a 2.5:1 ratio brings it down to 4000 max (at the clutch). Then your 12 tooth clutch and a 72 or 60 tooth final sprocket.
