Do you think this is a good deal? He says it only needs a back tire and i have no idea what that is under the seat. Looks like a sprocket. Also needs the pull start wound back up. No other problems as he says. For just $75.
from what i've seen on those. you can change the ratio like you would a drill press. change the belt to the other gear and now you can hill climb. move it out and you can go fast, etc etc..
good deal get it!!!!! I've been looking for a mini and they are all 300+ on CL where im at...
