DannyT
is there anything wrong with milling a head with a belt sander that's mounted to a workbench? How much is a good amount to take off for an OHV engine? I haven't taken measurements yet, so I don't know what the max possible is.
) and tape some fine grit wet-dry sandpaper to it.... With even, long strokes, sand away the amount you want. Every couple passes, turn the head 1/4 turn.....IF I was gonna do this, I'd use a pane of glass (or glass kitchen table in my case) and tape some fine grit wet-dry sandpaper to it.... With even, long strokes, sand away the amount you want. Every couple passes, turn the head 1/4 turn.....
