miles/gallon
r_chez_08
Should be in the shop...
Cornwall, UK
What speed, gearing, rear wheel, terrain? A lot of variables and hard to work out, but unless you are going to be doing many miles a day in your go kart, the mpg isnt a huge deal.
Rob
dave1701
Good for 100,000 Miles
MICHIGAN
Not to hijack the thread, but I've I've always wondered: Does would an engine with no load on it at the same rpm burn less than an engine attached to something?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Yep, because it takes more fuel to keep it running the same RPM with a load.
redsox985
PA
Electric motors run out of charge in the batteries and need to be recharged which doesn't cost at the pump, but you still get that bill in the mail. The down side is that once they're dead, they're dead and you need to plug in. I would estimate a stock clone to get about "a lot of miles"/gallon.
on a honda clone, how many miles to the gallon do you get?
Not to come off mean here, but-
Who cares?
Okay- that said- if you cared for some reason, you'd have to do some testing and average your results for a decent answer. With the very same engine I could get you 50+MPG on one vehicle, and 1 MPG on another...
Gotcha. You needn't worry about it. Even with my big engine pushing that retardedly heavy kart, I doubt I used 2 gallons a season- and there was some pretty heavy use.
