Last year, I pulled my go kart out of storage and went about fixing it up. While I had run it earlier in the year, it sat long enough, with fuel in the carb bowl, that the entire carb was shot. Along with some other upgrades, I replaced the stock Predator 212 carb with a Mikuni V22. I know that it is not a true Mikuni carb, however, I know it should work. I got everything installed early this year but ended up setting it aside (stored in the garage).
This week, I went back to it, and last night, I was finally able to start it. I worked on it more this evening, but now I am stuck. The engine will start with the 'choke' (fuel enrichment) on, but if I turn it off, even after the engine is warm, the engine dies. With the choke on, if I give it any throttle, it dies. And it sounds, and feels, like the idle is too high. What I mean by this is that, not only is it louder, but the RPM's are high enough that the torque converter is starting to engage, and the kart wants to pull forward.
I've already disassembled and reassembled the carb multiple times in the last two days. It is clean. The main jet is brand new. The other jet is clean and not clogged. The fuel is fresh and flowing into the carb (the bowl is full). It really does not seem to matter how I play with the adjustment screws either. At the moment, I'm really not sure how to proceed. Again, it starts, and will stay running with the choke on. But I can't turn the choke off, and I can't give it any throttle at all. The symptoms would point to it running lean, but again, the main jet is new (and large), and fuel is actively flowing...
