PredatorOfThePredator
- Messages
- 7
- Reaction score
- 0
Hey guys, I’ve been having issues from the beginning on my predator 301cc build. My engine is built to the max as much as possible (rod, cam, valves, etc.) and I’m having issues with it running properly. The engine won’t start & idle unless I give it gas and have my idle screw about 90% in. And then my idle is too high and engaging my clutch. Once it’s running I’ll back it off to a comfortable idle and when I start riding, it’ll die if I let off the gas even for a second. I’ve adjusted my jets down from 260 to 180, changed spark plug, and still running rich if I check my spark plug. The last thing I’ve done is put a 160 jet in and couldn’t pass 1/4 throttle or it would bog, and plug is still black. In terms of power the best the engine has ran is with a 260 jet, with idle issues and black soot on spark plug. My carburetor is a Mikuni TM Flatslide 28MM. Thanks for any input
https://offerup.co/7iCSMre5N4
---------- Post added at 07:32 PM ---------- Previous post was at 07:31 PM ----------
