chados
Hello, I write from Russia, through Google the translator, excuse for it mistakes.
In Russia it is a little developed completion of clone gx 200 motors, there is no information, there are no councils.
I have lifan 168f2 karting, a compression ratio about 10, channels are chiseled polished, an exhaust of 30 mm a pipe, the limiter is dismantled. I want to improve work as the carburetor of a mikuna of 22 mm. 5000 RPM more I won't allow to twist my maximum turns 5500 RPM. What jets are necessary for this carburetor, for the moment in the lower RPM?
Above 5500 turns it is impossible, I try to hold a resource. I want to achieve stable engine performance and response to overclocking.
Thank you,
Max.
Thank you,
Max.
