The motor is new (60363, the hemi configuration), with the Bullfrog domed high compression piston (11:1), Isky Black Mamba cam, 26# springs, mildly ported intake and exhaust runners, billet connecting rod/flywheel and a free flowing exhaust. It should easily turn somewhere between 7000 and 9000 rpm, but now won't really pull beyond about 4000, that's when it cuts out at 1/4 throttle.
I think I have a problem with the VM22 & I'm hoping you can help me with it.
It runs well at idle and up to 1/4 throttle. As soon as I try to go beyond 1/4 throttle, it shuts down as if it's running out of fuel. When I let it go back to idle, it runs again. The fuel level in the carburetor seems to be correct (it's about 9mm below the mating surface where the body meets the bowl).
Here is what I've tried so far:
1 - Changed pilot jet and it's at 12.5 now (but have tried a 15 & 17.5 as well), it runs well, idles well and pulls well to 1/4 throttle, then it shuts off at anything past a 1/4 opening.
2 - Tried both a 125 and 130 main jet, with different jet needle settings, the same problem happens at 1/4 throttle no matter which jet I use.
3 - Removed the main jet completely based on an article I read, put the jet needle in the center position, installed the carburetor again and ran it. Same thing, it starts, idles and pulls well to 1/4 throttle, then it acts as if it is not getting fuel. Let up on the throttle & it runs like nothing is wrong. It should run up to about 3/4 throttle this way, then start to bog from too much fuel as the needle opens too much.
It's frustrating to have to work like this and ask such a simple question, but any help you could provide would be greatly appreciated. tim
