Mikuni fuel pump, arc throttle plate
neebles
New Project
Illinois
I have givin up on trying to run my kart with my current fuel pump set up. I have a practically new Mikuni fuel pump, (square, 1 in 1 out) as well as the Arc racing throttle plate in which its mounted.
I would prefer to sell them together to save on shipping.
the pump was 20 new, the throttle plate was 25 new http://www.arcracing.com/servlet/Categories.
Im looking to get 35 shipped (plus pay pal fees) for the set. The fuel pump DOES work,and has not had very much gas through it......
neebles
New Project
Illinois
Im also selling the intake manifold with pulse fitting to run the pump as well...Goes in right in front of or behind your carb.
oldskool
I might be interested, if it will work on my 8 hp Briggs. If you have a carb too I would be interested as well.
oldskool
Parts
Well what type of carb was the pump and intake used for? Reason I am asking as I need a carb as well for my briggs to see if it will fit and work.
oldskool
Interested
Yeah sounds good, What exactly is a throttle plate? I will have to figure what carb will work with that setup later as i need parts soon. Hows 45$ for intake,pump and throttle plate? :drool5:
neebles
New Project
Illinois
The throttle plate basically is a plat that mounts where the gas tank was....You attach the fuel pump to it, and also, it replaces the throttle set up on the motor.....
Im not sure the throttle plate will work for you as its for a yellow clone...I dont want you to get it and have the screw holes not line up...Its up to you.
I would do 45 plus pay pal fees so to get technical, $46.65.
oldskool
parts
Sorry Neebles, I didn't here from you in a couple days so I odered a carb and fuel pump. The throttle plate probably won't work on my briggs. I'll ask around if anyone needs the setup that u have.
