mikuni carb, wisconsin motor
vandancouver
i picked up this old "pacesetter III" three wheeler. i traded a go kart for it. my cart has a modded 3.5 briggs flatty, this has a
8hp wisconsin robin motor on it. only problem is, i dont see anywhere to pull a serial number, and i cant find any info on the motor or threewheeler. it has a 8hp wisconsin robin im told, and it DOES have a mikuni carb. i took it all apart and cleaned it. does anyone have any info on this at all, or tell me where to go? also, i need some kind of picture on the minkuni carb, the float was off, im not sure if i put it together right. i think so..i lined it up and put the pin through the matching holes, but there was a small piece that had a "arrow" on one end that was in the float bowl part, i think i put that in right too, not sure. ineed a closeup view.
this motor is from the 70s im told. starts right up everytime
Kaptain Krunch
Pro Junk Collector
vermont
Need pics.
Unfortunately parts are hard to find for these wisconsin robin engines, i have one which i believe is also an 8 horse, its a flatty and has no spark, but great otherwise, and i cant find a coil for it, or even one that i could adapt.
vandancouver
this motor runs and starts up everytime. the flywheel, everypiece is sheared off. but it stills runs fine, strong and hard. what i need is some kind of breakdown diagram on thsi old minkuni carb i cant tell if i pt it back together right
Kenny_McCormic
Kartless....
Michigan Troll
Need pics.
Got points and a 12 volt source? Use a car coil.
