mikuni carb help
Sprout
South Alabama
I have a Manco goKart with a Robins Subaru 6.5 and a mikuni carb that I picked up from my neighbor - I am in need of a pic of the linkage to the governor throttle ect - any help would be appreciated!!
J_Walker
Florida
You mean you need something stronger then a coat hanger?
A piece of flat stock maybe 1/8th inch thick. as wide as you can keep it, you can drill a hole or two through it and drop a bolt into the holes that fit the hole size ontop of your carb. unless you have some way to punch out a piece of the flat stock and give it a 90 degree bend to fit into the given slots on top of your carb.
Sprout
South Alabama
The strength of the "coat hanger" is not the issue.... my issue is that I am not sure where the "coat hanger" and springs are supposed to hook up to on the carb
Sprout
South Alabama
Thanks for the video!
So as I saw it was a spring from the throttle lever to the governor
A rod and a spring from the butterfly to the governor
What is the rod that is attached to the top of the throttle lever??
jmoellendorf
i have a robin 6.5 that runs wide open the butterfly will not shut, Idles fine when i manually push butterfly back. From looking at these pictures am I missing a spring somewhere? Or do I need to do a governor adjustment? thanks
