Mid 70's Johnson Kart grave save
Chuckeroo
Springdale, AR USA
Hey guys.
I've started refurbishing my mid 70's Johnson Kart. It was in pretty bad shape. Lots of rust. I am not a body man, paint pro, or mechanic. But, I thought if I was going to put a motor and tires on it, I should try to make it look decent.
So, I've started the strip it to the metal and prime it phase. All sanding was done with either an small orbital sander or by hand.
Thanks
edit: just found the project gallery. Sorry, Ill post there.
J_Walker
Florida
Did you use etching primer? You should, that stuff is amazing!! Even if your paint gets knacked off, that primer will still keep ya from further rust!
Edit: did you look carefully over ALL the welds before paint!?
Chuckeroo
Springdale, AR USA
I'll be honest and tell you I know nothing about welds short of some arc welding I did in shop in the 8th grade. I can tell you that like Norm on Cheers I've reached my ideal weight if I was 11 feet tall and when I get on it nothing seems to flex :) I know, total noob here.
Didn't know about the etching primer. I used Rustoleum 2x.
Thanks
J_Walker
Florida
Thanks
To check welds, just look for bad welds/cracking/really rusty. simple stuff really.
Chuckeroo
Springdale, AR USA
I did do an initial cursory inspection and I don't recall any appreciable cracking or separation. However, it did look like several repairs had been done over time.
Thanks
J_Walker
Florida
Thanks
Its old, repairs are gonna be there.. Clearly this isn't a barn find after all! :cheers2:
