melting belts
sean
I have a manco dingo with a 8 hp off brand motor. I believe it had the wrong belt on it as it had no pull with the teeth down. Just for the fun of it I fliped the belt to teeth up and it had a ton of pulling power. But the belt melted. Where do I get a belt and is there any way to get rid of the stupid belt and use a clutch? The chain on there should be enough to pull this thing anywhere and I would rather use that as a source of power and not a belt that I will surly keep melting.
Kaptain Krunch
Pro Junk Collector
vermont
so your kart uses a torque converter? if so you just burnt up a $30 belt. There is absolutely no way a clutch is going to be as good as a TC.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200139524_200139524
sean
I would like to have a setup like I do on my quad. Clutch with a direct chain drive. I get to much slip on a belt and dont want that.
Kaptain Krunch
Pro Junk Collector
vermont
Its a torque converter, it shouldnt be slipping, there must be something stuck on yours. You cant get a clutch like your quad on a go kart without putting an actual quad engine in the kart.
sean
I guess I need to say it different. Its not slipping, I guess the things I am trying to do are to much for the cart and it burns up the belt edges. It that common or did it have the wrong belt on it in the first place?
EagleTalons
Master JB Welder
Forsyth, Montana
Well for one you put it on backwards. So it could only have a little bit of wear on it. Unlike the edge with the toothed sides. Which has alot of wear points.
sean
no. It wouldnt even pull a small hill or take off on flat ground without the belt not biting very good. I could put it in the back of my truck and hold the rear and gas it ans be able to stand there and hold it in place. (teeth down) Then I switched it (teeth up) and it pulled me into the back of the truck. I dont think it was the right belt. but I also dont think its going to ever pull hills very well either. I may just get rid of it
PitBoss
Kansas
Why does everyone hate TCs? They are awesome. Don't buy a clutch...
I think that the reason why is because when we get said TC used the person before didn't take care of it and now it is a pita to get working correctly. I am fighting a similar problem and I am still :mad2:.
modelengineer
Lord of the noise
Sydney, Australia
If the TC burns up, and there's nothing wrong with it, then a clutch will burn up 10x as badly, all else being the same (gearing). Also it will be much slower accelerating and lower top speed.
Try to get the TC working.
sean
The tc works great. I just dont like the belt thing. I am used to let go of the clutch and the chain makes it go. (quads) this is my first cart and I think i just got the wrong one.
modelengineer
Lord of the noise
Sydney, Australia
You can't really get a manual clutch for an industrial engine, unless you fab up a belt clutch like I did, or a completely custom clutch similar to that on a car.
If you want a real clutch you need a motorcycle engine (which is a double bonus because you get SO much more power and different gears)
sean
well I am in ohio by kings island (mason) and if anyone wants this thing let me know. Make an offer. i traded an old quad for it and I dont have any idea what its worth.
Kaptain Krunch
Pro Junk Collector
vermont
You giving up that easy? cmon man...trust me once that TC works right the whole kart will come to life.
