max torque 20 series strong enough?
realfast89gt
Kart Krazy!!
cibolo Tx
I have a murray kart with the max torque 20 series tc. I have read about the belt on these kart being too long compared to most other setups. If i have 10-12hp will this tc still be ok, or should i invest in a new one?
Also, what effect does such a long belt have on the tc, and if i do need a new tc will i be able to find a belt to fit?
thanks for any help. :cheers2:
r_chez_08
Should be in the shop...
Cornwall, UK
IMO:
10HP- Maybe, gear nicely.
12HP- Would not reccomend it.
Check out this for belt lengths, about halfway down the page.
realfast89gt
Kart Krazy!!
cibolo Tx
IMO:
By gear nicely, do you just mean near 6-1? It is 6-1 right now, but i did order a new sprocket so it will take it to 5.4-1 for a little more top speed.
r_chez_08
Cornwall, UK
How big are your rear tires? Basically just don't nail it, else you will eat belts! If you ask for too much speed with a large engine and low rated clutch, centrifugal type or torque converter type, you will burn something up.
r_chez_08
Cornwall, UK
I would say that would be OK with the 10hp, but cannot be sure, I have never overpowered a tc. Top speed 33mph governed.
realfast89gt
Kart Krazy!!
cibolo Tx
Yep, but once i add the offroad cam, valve springs, etc. the rpms will be 5800 max. so this is when i will be worried. I guess when i do the engine work i can try it and see if the tc smokes itself. :wai:
brycedevore
Have you taken the tc off the crankshaft and if so how I have it halfway off, but can't seem to get the part closest to the engine off?:toetap05:
r_chez_08
Cornwall, UK
If you start your own thread you will get far more responses.
What engine is this? 196cc Honda/clone?
Bluethunder3320
this happened to me once, i ended up having to cut the crankshaft off and replace it. i suggest you start a new thread
@realfast89gt, i would use a 40 series if you plan to go anythting over 10hp. i had a tc on a 10hp(stock) it worked but thats the max power i would put through it. the belt wore much faster than the old 6.5
you may be replacing belts all the time.
realfast89gt
Kart Krazy!!
cibolo Tx
R Chez: If you were talking to me about what engine it is, i have a tec ohh65.
Now if i did get a 40 series, would it be ok to get a bigger belt, or would i have to modify engine or jackshaft location and use the standard 40 series belt?
r_chez_08
Cornwall, UK
Don't think there is a 'standard' 40 series belt. You do not buy it in a kit form, just individual pullies.
Check out here for belt length.
Didn't realise you could get performance cams and uprated valve springs for the OHH65.
I would say stay with the 20 series for now.
