Hi guys,
Im new to the forum, Ive been reading a lot and found out that there are plenty of really knowledgable guys in here, which is great.
Right now I dont have any project in my hands, but im looking forward to start with my own karting in the next few months. The big issue is Im from Argentina, and nice tools (saw MIG welder, drop saw, etc) are really expensive, and I rather save for a nice one than buy a crappy one that wont last all that much.
The reason of this topic is Ive been refreshing my mind with gearing and jackshafts (Ive even made a nice excel sheet to make all those calculations, I can upload it and share it if youre interested) and run into a few "conceptual" doubts.
While calculating the max speed you can reach with your go kart, everything is asuming that the engine can make it to a certain RPMs, let say 3600. So, if you think than both, a 6hp and a 8hp engine could reach the same max 3600 RPMs, thats to say they both could reach the same final speed (asuming same gearing on both)? If so, clearly the 8hp will get there faster (due to the extra torque available) and that would be the only difference?
Following the idea, I'm not sure if, for example, the 6hp could actually get to the 3600 RPMs carryng a load of 180kg (say thats kart + driver weight), but I wouldnt doubt that the 8hp could get there driving the same weight. If that would be the case, the actual max RPMs of the 6hp could drop to a max of 3000 RPMs, wheather the 8hp could take advantage of the full 3600 RPMs. So that would add an advantage on the actual final speed the 8hp engine could reach (added to the fact that it "gains" speed faster). Values are just to put my ideas into numbers, Im just making them up more or less.
And a final thought, how is that the wheel diameter would affect the gearing calculations? I've been using wheel circunference for getting the km/h, but I havent involved its diameter for gearing purposes. If I think about it, it may be working as an extra sprocket, but because the gearing ratio is calculated with "teeth" and not using the actual radius of each srocket, Im having a hard time getting it. For getting the most accurate possible values, should the wheels be included in the calculations?
Ok, that was pretty long! haha, hope I find some guys interested in discussing this a little bit.
Thanks!
Mato
Thanks!
Mato
