Margay panther x identification and soon to be build thread
Thepartsguy
no Brakes! and how lucky can a person get? The exact brake system I had that didn’t work was for sale on ebay and it does work. the whole setup will be here tomorrow and I’ll have working brakes. E49C2019-E94E-453B-8342-F897B881A4F0.jpeg
I see both brake lines going to the back of the cart, so no front brakes. Only see one brake disc in the rear, are you using two calipers on it, or is one brake line just plugged off?
Thepartsguy
one line for each side is the best way I can explain it. no front brakes. Edit: also brake parts from Enginetics so yaB2294122-8C9A-4FB1-86AB-CEE9F2376C2B.jpeg9C37B8A3-47FD-409F-A90B-A3564F66E267.jpeg
Lookinforparts
Do you still have the spindles that did not fit? If so are you looking to sell them? I’m rebuilding a Panther X from late ‘70s and mine uses the short spindles and one is pretty bent. If you do have them for sale can you send measurements? Thanks!!
