Manco XTK-710E A-Arms Bent
ResilientMonkey
Endicott, NY
Okay folks, as mentioned in my other thread, I got a Manco XTK-710E go kart.
Among the few issues it has is a problem with the front A-arms. Both front wheels have a high amount of camber so it looks like this from the front: /---\
It doesn't look like they are adjustable. I might be able to do some bending if I have to.
I wondered if anyone had any thoughts?
I'm going to keep looking on the interwebs to see if I can find anything. I've kinda got an idea about making the camber adjustable on it using some rod-ends.
Are those the original coil-overs? It kinda looks like it might have had a different ride height at one time, or both are bent.
The joint area does look a bit weak in how it is constructed?
ResilientMonkey
Endicott, NY
The coil-overs are original... but there is very little clearance between the A-arms and the lower frame rail, so there is no way it sat much higher.
And yeah, I'm not too impressed with the structure of those spindle brackets.
Variable camber is always a problem with single A arm setups but, that is excessive, something is definitely bent...
Put the front on a stand & remove the front wheels & shocks, then closely examine the spindle bracket area; post pics so we can see, ATM, I can't see anything past the shocks...
