Manco Project Engine/Clutch Guidance Needed!
Houdini
Richmond, VA
Well, that was fun while it lasted. One wheel came free, the other did not. So now I need a new axle, sprocket, brake, bearings, wheels and tires (PO glued tires on apparently, can't break the bead to salvage at least the tires). Might have to write this one off. So much for just needing to drop in a new engine.
rocketkart
florida
if you till looking for a engine? i have one. its a older 11hp wisconsin robin engin in my opinion one of the toughest and best engine ever made but sadly never found a use for it i also have a TC that fits it.
I assume its a comet 40 series, because a 30 series just won't cut it with that engines HP
Houdini
Richmond, VA
I appreciate it guys, unfortunately I only had the money to add an engine and TC, I didn't realize I was going to have to replace the entire live axle drivetrain too, which would in essence double the cost going well past the value of it in the end. Lesson learned I reckon!
rocketkart
florida
yes it has a comet 40 series on it belt an all. ready to go on somthing fun just i dont have anything at this time for it. i was going to put in a golf cart but the frame was rusted all to hell and the body was in bad shape so off it whent to the scrap yard. $150 for the angine and TC shiping will be about $50 so anyone who needs one let me know cus i hate to just see it set on the shelf at the shop.
Half-breeder
"Edit" button removed
:smiley_omg: sounds like something i been lookin for(...well, 1 of the deals...)!
There are other ways to free up axle components, post some pics of the axle, we'll get this axle stripped if it kills you :lolgoku:
Start by sanding the axle between the components &, if possible, knock out the keys; it doesn't matter if they get damaged, they're cheap to replace.
Once you get the keys out, the circular movement will help to free everything up...
DON'T GIVE UP :thumbsup:
