Manco Intruder w/Subaru Robin engine
Bsix16868
My kids ride this kart and I noticed a week ago that the gas tank was loose. As I checked it out, i noticed one of the bolts had sheered off and the other was missing the nut. The vibration must have caused this. I JB Welded a new bolt onto the gas tank and added lock washers and locktite. Now a week later the weld has broken and the other hold down bolt has sheered off. At $80 for a new tank I’d rather strap the tank down somehow. Anyone had this happen to them? If so, what was your resolve?
Welcome to the forum!
Your kart must have some crazy vibration. Maybe post a pic or two of where the bolts attach. Are you able to weld the bolts back on? Not with JB weld, but proper welding.
I think the gas tank isn't double walled in the bolt locations.... With all due respect landuse
...I will seriously NOT recommend welding a gas tank... Just too dangerous...
Solder with a good electric iron or copper might be able to getter done with good prep work...
No fire...
A pic on how the tank looks, might be able to use a gx200/clone ect. tank, or shoehorn one with some bracketry to make fit...
gokartdaddy
MARYLAND
bungee cords or large metal or plastic zip ties ?
Temporary fix, but if secured tight would cut down on the vibration.
What about rubber washers ?
No fire...
I wasn't even thinking:ack2::roflol: :D
Thats why we have experts like you guys to stop me :D :D
Bsix16868
Thanks for the replies. It’s been crazy raining around here so I haven’t been able to do much. The rubber strap looks like a good idea. I tried earlier to get the tank off but the hose is so short there isn’t room to get at it.
