Manco interceptor identification?
Jedibrad
Franklin n.c.
Does anyone know what model number/series this kart is? Thanks
Wow, you seem to know the maker and the model name. That seems to be all you really need to know, right? A lot of people are never able to identify what kind of kart they have. :(
The labels and decals look intact, look for the model number there.
If no luck there, I think Gewgle is your friend.
Jedibrad
Franklin n.c.
It's in pretty good shape but Gonna need several things...and some of it has been jerry-rigged and curious to know how it was originally...lots of manuals online but having trouble locating that particular one...parts diagram would be awesome...
Jedibrad
Franklin n.c.
Right...that's exactly where I've been looking...see harder than one would imagine to figure out....looked thru all of them I think and can't seem to find that particular one lol
---------- Post added at 07:32 PM ---------- Previous post was at 07:06 PM ----------
Update- woohoo think I found it ...model 104 I think
---------- Post added at 08:09 PM ---------- Previous post was at 07:32 PM ----------
Or you found it...woohoo...lol
So it comes back to... what exactly are you looking for?
Parts wise... Engine, wheels, steering, axle are all basically the same thing amongst the yard kart verities..
Jedibrad
Franklin n.c.
Well someone has apparently spot welded the sprocket/brake to the axle and they are about wore out...guessing it's missing a bushing/spacer or bearing err something to be correct...kinda hard to get the axle out with out grinding it lose and just need a plan for putting it back together without welding another one back like that
With a typical live axle setup(simply a piece of keyed shaft), they'll have a hub that's welded(or you can bolt) to the sprocket and another for the brake...all held with shaft collars(for extra security) and setscrews... No welding should be placed Upon the axle for any reason...
How about some pics of the axle setup you have...
Jedibrad
Franklin n.c.
Maybe I'm wrong..maybe the brake hub is just welded to the sprocket...I know it's hard to tell from picture but when you spin wheel the brake hub is like a half inch out of balance and it just appears like a really crappy weld that someone has done at home. I just don't have any experience with go karts this is my first build and I could very well be wrong
Fancy way of saying live axle, yes.
From the exploded view diagram, it appears the brake drum and the drive sprocket are a "unibody" design assembly. One-piece from the factory. It's only supposed to be keyed to the axle. No welds or other funny business.
Most of the prior karts Manco made, the axle was exposed and supported by bearing hangers right from the frame. This one and a few others have it riding inside a sleeve, a casing, sort of automotive style.
