Manco Go Kart with Briggs
eaglesguy1981j
I have a Manco go Kart I bought for my kids some time ago. Its a Briggs motor and sure its 5hp fun power. Runs centrifugal clutch and belt system. When we ride it it seems to well at first then it seams to sorta stall. Engine running fine it seems to be in the clutch area. I can see everything moving and even the clutch expanding out as RPM increase but no movement with the cart. Ive tried taking the clutch apart and cleaning but doesn't seem to help. Can anyone help me diagnose this please?
Could you post some pics of the engine and clutch? Could you also give us the tooth count on the clutch as well as the axle sprocket? If you are using belts, could you give us theit diameters?
We should be able to help you out
eaglesguy1981j
On the big spocket there is 61 teeth on the small there is 9. Belt is 27" Really rides nice but after its been riden a bit the motor still purring, I can see the clutch engaging and the belt catching cant remember if it was slipping or not. But it wont move. It will surge forward just a bit but no movement.
eaglesguy1981j
THat could be I think I will try cleaning it and a new belt. I seen the belt says MANCO so im wonderin if it might be the stock belt. Would a 3/4" 27" V belt from the hardware store work or is this a factory only deal? Im cleaning it up to sell since my kids no longer ride it and its taking up garage Any clue what one like this might be worth? Its in decent condition I just got a few things to Iron out before...
Jake.B
California-USA
Im not posotive but ive heard of these things running oddball belts, i would find the belt made specificly for it.
eaglesguy1981j
Cleaned the Torque converter and it really seemed to take off better and grabbed better. Ill give it a whirl this weekend again. Thanks for the help fellas
