manco go-cart frame
Windyhill
hey I have a manco go-cart frame, I recently bought a 9hp B&S engine, I am wondering what a good clutch is to put in it to give it uphill power and speed at once, without spending a fortune!
KartFab
Dallas, TX
With a centrifugal clutch you could get speed, but not torque to climb hills.
With a centrifugal clutch, and jackshaft, you could get low end torque, but no real top end speed.
With a torque converter, you will get both low end torque, and a higher top end speed.
Look into this sticky for more information.
http://www.diygokarts.com/vb/showthread.php?t=18371
If you go the centrifugal clutch route, it might cost you about 100$ for the clutch if its a 1" shaft, and you will need to 'gear it low' to avoid burning up the clutch if you plan on riding up any thing other than a small hill.
Gran_pan has pretty much summed it up for you. If you want to offroad and climb hills, I would probably go for the Comet 30 series TC. It is more expensive, but it is more suited for what you want to do
Post a pic or two of the back of your kart. Does it have a jackshaft already? If not, that will be an extra expense if you use a centrifugal clutch
Windyhill
thx! all the frame has really is the main frame, no wheels and no parts really except for brakes and throttle. its needs some work but is was cheap. So what you are saying is to go with the torque converter?
