Manco Dingo 8HP Help
a1parrothead
Hello all,
Just bought an 8hp manco dingo and am fixing it up. My question is about the front shaft that part of the torque converter mounts to. On the OPPOSITE side of the engine from the belt and sprocket, you can see that shaft at the front of the engine where it passes through a bearing (Mine had a red plastic cap covering it), my question is: Does this look right? Its just a nut up against the bearing, and does not seem correct to me.
If someone could help, or even post a picture of theirs, it would help!
Staff Murderator
However, a washer added to what you already have there might take up those valuable spare threads you have on the end. You typically don't want a nut or fastener dangling on the last threads if you catch my drift.
Is that nut there as tight as it needs to be or is the jackshaft loose in its housing?
a1parrothead
Its secure. I added a proper washer and had plenty of thread from the other end to steal. All tight and looking proper.
