manco clutch help
beagledogxxx
Hey all...Bought the kids a used manco black fox xlt with a 6 hp tecumseh on it. The clutch has a 6 inch driven and is 6.75 inch center to center on the shafts. Green spring in the driven. Assymetrical belt that measures 5/8 on top and is marked 5959. Low end was real bad so moved the spring to hole 3 and now it wiped out 4 of the 6 buttons. Just wanted some input as to whether or not this is the correct belt because it looks way too loose and who knows if the previous owner had the right one on there. I don't have a manual and can't find out much on this particular model of kart. Thanks a bunch
beagledogxxx
I think i figured it out. I believe the previous owner thought he had a cat99 using the 5/8 belt when it's really a 30 series needing a 3/4 inch belt. Either that or the belt has been worn down from 3/4 to 5/8 just from use, which would seem like a pretty big coincidence that it just happens to be at exactly 5/8 right now.
Can someone verify for me that a 5959 belt is a 5/8 belt? Thanks
beagledogxxx
Ok...i see now the 5959 is a 3/4 belt and mine is just worn down to 5/8 so that hopefully would explain the poor performance and probably have something to do with why it threw its buttons. I think...any suggestions?
beagledogxxx
Thanks for the link to the chart. My center to center measurement 6 11/16 which is smaller than anything on the chart. 6 15/16 to 7 inch is the closest on there to what I have. I guess I should go with the closest belt on there and hope for the best. Not sure what else to dol. 203589 and a new set of buttons looks like the way to go.
anderkart
Surprise Arizona USA
I think your going to have problems, the belt lengths are very critical.
Is your jackshaft frame mounted, or on a plate bolted to the engine like this pic?
(if it uses a plate like this, they probably just bolted it to the engine through the wrong holes...)
beagledogxxx
Its frame mounted but i'll see if any movement is possible before I place an order. Thanks for the tip.
beagledogxxx
Well, i pulled the motor, slotted the holes as suggested and bingo....dead on perfect. Just gotta figure out why i keep losing buttons on the driven. Thanks a bunch for the help.
