I was wondering if someone could shed some insight into the throttle linkages on a Manco 710e. I bought this go kart not running and it seems to be missing some odds and ends. It appears that the cable from the gas pedal would operate the governor and also the mechanical linkage direct to the carb. However when I press the gas pedal the only thing that happens is that the mixer lever (for lack of proper terminology) moves and the throttle stays full open and the governor arm does not move either. I appreciate the help and insight. The engine referenced is an EX27 subaru robin. My assumption is that I have one missing spring and one bad one. Thank you in advance!
